Error -1074135038 occurred at IviScope Initialize With Options.vi
I'm new to LabView and to IVI drivers, and I'm having problem connecting to a LeCroy LT344 oscilloscope.
I have LabView 12.0, MAX 5.3 and the lctlxxxx IVI driver installed. I already configured the driver, and I can use the VISA test panel to communicate with the scope. However, when I try to run the IviScope - Acq Wfm Edge Triggered.vi example (after choosing the IVI Logical name), it gets stucked in the IviScope Initialize.vi block, and generates the following error:
Possible reason(s):
Primary Error: (Hex 0xBFFA0002) File could not be opened.
Complete call chain:
IviScope [CA] - Cont Acq Wfm Edge Triggered.vi
I really appreciate any help on the matter.
Thank you,
  Vinícius
(3,166 Views)
I think is a double Post?
http://forums.ni.com/t5/LabVIEW/Error-at-IviScope-Initialize-using-lctlxxxx-driver/m-p/2123946
Are you trying to use the NI-Scope to control your Hardware?
IviScope vs. niScope Hierarchy
http://forums.ni.com/t5/Instrument-Control-GPIB-Serial/IviScope-vs-niScope-Hierarchy/td-p/1830727
Ni-Scope:NI-SCOPE 3.9.4 - Windows Server 2008 R2 64-bit/Server 2003 R2 32-bit/7/Vista/XP 32-bit
http://joule.ni.com/nidu/cds/view/p/id/3195/lang/en
Which IVI Class did you install or your hardware use?
I found something about IVI 1.4 Class. I'm not sure if it helps
http://www.ivifoundation.org/downloads/Class%20Specifications/IVI-4.1_Scope_2011-02-14.pdf
Best Regards.
Kais Mekacher
AE Germany-Munich
Kais Mekacher
Germany - Munich
(3,118 Views)
