registering alarms in event structure
I am currently using LabVIEW 2011 SP1 and the DSC module. I can dynamically register shared variable alarms in my event structure; however, this only triggers an event when the variable goes into an alarm condition. I also need to know when the alarm clears.  Any ideas?
(2,816 Views)
Can you show your code or give an example code?
(2,789 Views)
I just did some of this in 2010 and it fired on both conditions (automatically, I think).  Are you certain it's not, ie, have you probed and stuff to check?
Tim Elsey
Certified LabVIEW Architect
(2,783 Views)
Accepted by topic author NNS-CAO
I figured out the solution. I set the alarm to auto acknowledge and then it triggered the event on alarm clear. It would not work with it set to user acknowledge.
(2,761 Views)
