Error -1074395984 occurred at IMAQ ReadFile
I received some images that I cannot open in LabVIEW. I can open in Matlab, Windows viewer, ImageJ and other sw but not in LabVIEW where I get this error :
Error -1074395984 occurred at IMAQ ReadFile.
I can forward you the image but it is huge (bigger 100M). Here below the link to download it:
https://we.tl/t-Dz5HTQHU0J
Thank you
(4,171 Views)
The Error Message is "NI Vision does not support the file data type you specified."  What is the file data type?  I'm sorry, but our firewall does not allow importing huge files from untrusted sources.  If it is only a "file format" problem, open it in one of your other programs and save it in a file data type that LabVIEW supports for image files.  [It's not a video, is it?].
(4,144 Views)
Hi Bob,
the file is in png format. I opened with ImageJ and saved in TIFF, but still not able to open in LabVIEW. Then I saved into bmp and it works.
The format of the data should be in single precision. I doing some check.
Thanks.
(4,142 Views)
If you are using IMAQ ReadFile, .png, .tiff, and .bmp should all work (though .tiff, as I recall, has extra "stuff" buried in there).  "The file format can be a standard format (BMP, TIFF, JPEG, JPEG2000, PNG, and AIPD) or a nonstandard format known to the user."
(4,137 Views)
These are the information I can get from ImageJ:
Title: DUT_Image20180828_173355.png
Width:  5120 pixels
Height:  5120 pixels
Pixel size: 1x1 pixel^2
Bits per pixel: 32 (float)
Display range: -0.0066 - 0.6644
As mentioned the data single precision, but this format should be supported by the IMAQ read.
(4,131 Views)
And it certainly is supported!  The third choice for a Buffer Type is "Grayscale (Sgl)".  You failed to post your code, so I can't tell what you did, and can't explain your error (if, in fact, there is one), but this Snippet should read and display your data file --
(4,125 Views)
