Error -1074395995 occurred at IMAQ Reading
i'm getting Error -1074395995 occurred at IMAQ ReadFile.
(7,507 Views)
IMAQ Vision:  File not found.
Look at your code (which you failed to post).  Look particularly at the IMAQ ReadFile.  What is wired to the FilePath input?  Are you sure there's a file there?
Bob Schor
(7,484 Views)
I get the same problem.. Some images work and some don't. All of them are JPEG but the only pictures I can open are windows own "Sample Pictures". How can I solve this?
(7,313 Views)
Could you please attach your code?
Check the image path you are providing for reading the image.
Else check for format of image you are reading while creating a buffer from  "IMAQ Create VI" Image Type.
(7,305 Views)
