Is there an event for frontmost change?
Is there an event that will tell me when the VI looses frontmost? I'd like to make a sort of deadman trigger that fires when the front panel isn't frontmost. If it comes to it, I'll poll FP.isfrontmost.
(3,424 Views)
Use Property node for the respective VI and you will get whether the VI FP is Front Most
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(3,391 Views)
Accepted by topic author nanocyte
Look at the Application class event called VI Activation (or VI Deactivation, if your version is new enough). You might need to activate scripting to see it.
___________________
Try to take over the world!
(3,382 Views)
