Error -1074397163 at IMAQ inti for USB camera
I plan to use labview to control a Thorlabs DCC1545M camera. Firstly I want to snap a picture or grab pictures. When I run my program, it show me Error -1074397163 occurred at IMAQ at Snap.vi or at IMAQ Grab Setup.vi. It seems the error come from the subvi IMAQ Init.vi whicn is include in both Snap and Grab Setup vi. When the program run at imgInterfaceOpen.vi under the IMAQ Init.vi, it retrue a number --1074397163 form the return parameter:return type. This is the situation I got.
The interesting thing is that I could run the similar program successly if I replace the all IMAQ by IMAQdx. It is because my camera is a directshow camera which can not connect by IMAQ? Can I use the IMAQ to snap picture not IMAQdx, What should I do? Thank you so much
(3,486 Views)
First of all you need to check this.
And if you have any issue with the Direct Show cameras you need to look at this.
(3,470 Views)
