Error 10845 in VI Logger with NI 4350
I have just installed VI Logger 2.0 full version for use with my NI 4350 USB box. I get an error in a simple analog read of 10845, Data could not be read from my devvice fast enough. Is there a wy to slow down the sampling or speed up the bus speed? Thanks
(2,633 Views)
MDH,
What is the frequency of the signal you are acquiring? How fast are you actually accumlating the signal in your DAQPad? The reason I am asking is because the transfer rate is basically the USB rate and this should not be an issue. Could you please tell me whether you are running in a finite acquisition mode or continuous. In case you are running finite, what is the number of scans specified for the channel? I await your response.
Ayman K
(2,625 Views)
Thanks for the feedback. I've just discovered that the error only occurs when I try to extend the real time graph out more than 5 minutes in a screen with the help on the right and about 9 minutes when I extend the chart screen out after closing the help. Since the 4350 requires the Nidaq traditional. I'm not able to control the sample rate. Its greyed out at 60.00 sample/sec.
(2,618 Views)
