Error 1335 during installation of NI LABVIEW Run Time Engine 2009
While installing Labview 2009, I am getting the following error.
Error 1335 : The cabinet file 'mib100.cab' required for installation is corrupt and cannot be used. This could indicate a network error, error reading from CD -ROM, or a problem with this package.
I tried installing the software using 2 different CD-ROMs and also from the hard-drive. I also uninstalled previous NI software and tried installing Labview again.
Attached is the screenshot of error during installation from hard drive.
Thanks in advance,
Sayali D
(5,944 Views)
Have you tried it on another pc to see if there might be a problem with your DVD reader?
(5,943 Views)
Yes, installation was successful on other PCs before.
(5,936 Views)
Well, there you go.
(5,930 Views)
So, shall I just try installing it from a netwrok drive?
Sayali D
(5,927 Views)
Or replace the DVD drive in your system.
(5,925 Views)
Accepted by Sayali
The installation was successful after replacing the DVD drive.
Thank you!
Sayali
(5,894 Views)
