Error 1430 occurred at Copy in Untitled 1. Possible reason(s): LabVIEW: The path is empty or relative. You must use an absolute path.
I have written a code to copy a file from one folder i.e C:\Folder1:\Hello.txt to another folder C:\Folder2. But it is showing an error in the copy. It is showing Error 1430 occurred at Copy in Untitled 1. Possible reason(s): LabVIEW:  The path is empty or relative. You must use an absolute path.  Can someone please help me how to solve this problem. I have also attached the VI. Thanking You.
(4,215 Views)
Accepted by topic author vindsan123
Change While Loop to For Loop !!!
With Best Regards
Certified LabVIEW Architect (CLA)
(4,198 Views)
Thanking You for your kind reply. Could also clarify me as to why did for loop worked but not the while loop. Thank You.
(4,189 Views)
because stop condition for while loop is Your stop button. for "For loop" stop condition is number of files in folder, because You turn on autoindexing.
With Best Regards
Hrachya
(4,180 Views)
