How to separate samples I/0 signal?
Hi people,
I got a signal which is high in ~10ms and low in ~1ms. I'm only interessed in the samples that are in the high state.
I tried with the Waveform Get Subset DBL but without any luck. Is there another way or did i just misunderstood the values start sample and duration?
Thanks in advance
Message 1 of 9
(4,006 Views)
Hi anja,
try something like this:
Using conditional tunnels in more recent LabVIEW versions will simplify this snippet image even more!
Message 2 of 9
(3,995 Views)
Hi GerdW
Thanks for the fast reply.
It looks like it would work. I supposed that you look at the values and apply greater than 2. But I have one issue that my signal can vary all the way down to 0.5 V at the high state. (it depends on which surface i place my sensor on).
So i guess I needed it to be calculate on the time the signal is high?
Message 3 of 9
(3,982 Views)
Hi anja,
you could change the comparison to compare with "minimum of the measured signal plus a small offset"…
Message 4 of 9
(3,964 Views)
Yeaah.. but in some case my signal can look like this and I'm not certain of with offset i should use beacuse the varied signal. The one thing im certain about is the time when it high and low, so i would look it to depend on that? Any good ideas? 🙂 InputSignalLowValues.PNG
Message 5 of 9
(3,956 Views)
Hi anja,
your LOW signal seems to stay below 0.05. I still would prefer a simple comparison!
Why make things more complicated than they are?
Message 6 of 9
(3,937 Views)
Yeah, but a third scenarie, agian I can place my sensor different places which gives different input.
Here is my low signal ~1,75. So as you can see the low periode can vary alot. But yes I would like to use a simple comparison, but I dont think it would work en generally if do not depend it on the time?
Message 7 of 9
(3,920 Views)
Hi anja,
some messages before I wrote "minimum of signal + offset"!
So you could get the minimum of the signal (~1.75), add 0.1 as offset to get a comparison level of ~1.85.
To reduce the noise I would adapt a running average over some samples…
Message 8 of 9
(3,910 Views)
Hi GerdW
Okay, Im getting to see what you mean. Could you show me hoe to implement the small offset to the minimum?
I would surely do it as simple as I can, but do you have any ideas how to control it by the time?
//Anja
Message 9 of 9
(3,901 Views)
