Error -1950679007 when I try to create shared variable binding automatically
Hi All,
I'm using LV 8.5 with DSC.
My aim is build shared variable library automatically. A program read variable name, data type and network binding address from .CSV file. Program works well untill I add this "bind to source" property. I don't know what goes wrong. Does anyone else have found this same issue?
Picture about problem is in attachment.
The error codes are found here:
Other useful information:
(4,761 Views)
  The error is due to some common mistake, why iam saying is before i also had a trouble  like you, but  finally i got  solution for that. Anyhow i cant guess exactly  this is the problem in your case. but i had sent you  a image file it may be helpful to you. Still  if the problem exits, send your sample vi's to me.  I will help you.
vijayakumar.v
(4,705 Views)
I wasn't able to find your file. Please can you send file here? I haven't solved problem yet...
(4,698 Views)
i am unable to attach the file. i dont know why i cant upload my file.
 Regards
vijay
(4,687 Views)
 The error is because , in the image u have sent(property) , Network.UseBinding  property should be above the Network.Url property.
because Network.Usebinding  property should be enabled first ,then the URL input should be given. i hope this solves the error.
regards
Santosh Kumar
(4,467 Views)
 Now i able to attach the file, While creating Shared Variable,Enable the options which i given in the image by same order. So i think it will solve this problem. If it cont., i will give some more suggestion.
With Regards,
vijay_Conz
(4,452 Views)
Hi, vijay_Conz
Thank you very much. Your example picture solve the problem.
(3,487 Views)
