Error 200019 when I use 2 pressure transducer
Currently I’m using 2 pressure transducers connected to NI 9237. When I run my experiment, error 200019 appeared (as attached in the pic). Before this I used only one pressure transducer and I dont have this issue.
I’ve tried some solutions suggested in the forum such as reduce the sampling rate but the error keep appearing.
Can i get some advices/suggestions to solve this issue?
Your help are greatly appreciated.
Thanks.
(1,222 Views)
It's pretty much impossible to debug a  picture of your computer monitor just as you mechanic can't look at a picture of your car and figure out why it won't start.
Are you even working in LabVIEW?  This is a LabVIEW forum and you've posted a picture that looks like Signal Express.
If this is a Signal Express question, then repost your question in the Signal Express forum.  Attach your SE project to that post and someone might be able to look into your problem.
(1,209 Views)
