Error -200220 occurred at DAQmx Create Channel (AI-Voltage-Basic).vi
I am trying to set up my PMT using NI-DAQ 7.3 along with Labview 7.1.  I keep getting an error message described above.  I am new to this program, so I am not sure what is wrong.  I have also received an error message stating the device could not be routed.  Any ideas?  Thanks
(2,877 Views)
Did you install the last version of DAQmx ??
Maybe the driver needed to control the PMT is updated in the last version...
CLA, CTA, LV Champion
View Cyril Gambini's profile on LinkedIn
This post is made under CC BY 4.0 DEED licensing
(2,872 Views)
Hello WayneState,
Welcome to the NI Forums. The error message should say something like this "Possible reason(s): Measurements: Device identifier is invalid." This means that the name of your device was incorrect. You should use the drop down box to select the one is configured in Measurement and Automation Explorer (MAX).
There is very valuable information in this site since it is designed for people starting with data acquisition using our products.
Finally, I see you have other problems in this LabVIEW thread that suggest that you have already overcome the error in this Thread. If so, please post back your description of the resolution and if not, please feel free to post back some screenshots of MAX and LabVIEW.
Gerardo O.
RF SW Engineering R&D
(2,848 Views)
