Error 200279 How to fix it?
That's a picture of your code.  But it doesn't describe the delay you are talking about.
And what is the point of the amplitudes and levels subVI's?
Message 11 of 14
(1,704 Views)
Sorry, I do not understand your question
Message 12 of 14
(1,698 Views)
Sorry, I don't understand what you are trying to do in your code.
Message 13 of 14
(1,694 Views)
@JoseGo94 wrote:
I managed to acquire the amount of data required (10 samples / second). Only that there is a delay between the physical measurements and the data that I acquire. For example, my LVDT changes 1.1 in to 0.5 in, while the numerical value of labview is still 1.1 in.
Since you used Express VIs we can't see what your settings are from your pictures.
My guess is that you are acquiring data and then your analysis in your processing loop is adding a delay between when the data is acquired and when it is displayed. Whatever processing that happens between acquisition and display is unavoidable.
Cheers
Message 14 of 14
(1,693 Views)
