Error -200279 in Analogue & Digital inputs
Hi anon,
If I increase the sampling rate I get the 200279 error. This usb-6001 may be low spec but it has up to 20kS/s so it should be able to give 1000 samples over a 10 sec period.
I did NOT recommend to change the samplerate!
I suggest (aka "strongly advise") to get rid of the DAQmxRead with just "1 Sample"!
Read blocks of 100 samples as you did before (as it seems from your quoted message) using DAQmxRead with mode "1 channel N samples"!!!
Message 11 of 13
(448 Views)
OK, I changed the sampling rate and removed the queue. The problem is that my data is not passed from one while loop to the other. If I uses the queue then obviously the main loop waits for the secondary to output data hence there is a delay. Any suggestions?
Message 12 of 13
(441 Views)
Hi anon,
In your VI you didn't need to transfer data to the other loop…
You could use a timeout on the Dequeue…
Message 13 of 13
(439 Views)
