Error -200279
I get this error in the code and I don't actually know why, it happens
usually after the code ran at least 200 iterations.
I also get a -200284 sometimes (really weird because it only happens in
the first couple of loops and it doesnt happen all the time).
The errors come up after the second CountDown.vi (from left to right).
I attached a link to the pic with the part of the code that shows the
error, any ideas would be greatly appreciated.
Our systems (if needed)
Laptop P4 2.6GHz, 512 RAM, NI DAQ6024E
http://plaza.ufl.edu/xchus/Work/Complete%20VI.jpg
Thanks in advance.
(2,732 Views)
I saw that this post is also on the Multifunction DAQ discussion forum.  Since it is a DAQmx error that you are getting, I will post there. Please see your other post for my recommendations.
Jennifer O.
(2,710 Views)
