write data to excel when this in use
i am wrinting data to excel ok but i have one while loop to open workbook and sheet repetitively so i need use excel internally form i am not bothering TO USER THES EXCEL
(2,536 Views)
Hi wilyboard, there is a way do do whit but you will have to work with active x rather than with write to srepadsheet.
You can find an example of using active X with excel in the example finder
If you have the report generation toolkit it can be done as described in the following link
http://digital.ni.com/public.nsf/websearch/E97C9BEF7E53841E86256A41004F0809?OpenDocument
This explains for cvi
http://digital.ni.com/public.nsf/websearch/07C5C41D90142EE886256F8D0007AAE3?OpenDocument
Also we have Spanish community message board where you can paste your forums directly in Spanish
Message Edited by BeCeGa on 10-02-2006 10:26 AM
Benjamin C
Principal Systems Engineer // CLA // CLED
(2,505 Views)
