Error 200288 and 200609
I am attaching a simplified version of the code I am having trouble with. I am attempting to send an AO signal (1000 Hz) across three seperate channels on a USB 6229 board. I continue to get the error 200288 saying "attempted to write a sample beyond the final sample generated."
If I run in continuous mode instead of finite then I get the error 200609 saying my buffer size is too small. I have attempted to change the buffer size but I can't seem to make anything work. Any help would be great. Thanks
(3,148 Views)
I have been looking into this issue for you but for me to proceed any further I need a little more information.
Would you be able to clarify exactly what you are trying to do?  Would you be able to provide an example of the kind of signal you need to output?  Do you need to configure the buffer yourself or are you ok letting LabVIEW do it automatically?
Tom Clark
National Instruments UK & Ireland
(3,060 Views)
