Creating a DLL with the appbuilder that returns a bool
i need to create a dll with the appbuilder that returns bool. but i can only set the returnvalue to nummeric or string..
the prototype should look like this
BOOL MyFunction(UCHAR ucANTChannel, UCHAR ucResponseMsgID);
**original callback function: typedef BOOL (*RESPONSE_FUNC)(UCHAR ucANTChannel, UCHAR ucResponseMsgID);
is this possible?
thank you
martin
(2,667 Views)
Hello Martin,
BOOL is not an C or C++ data type. The type BOOL is somewhere defined either with an macro like
#define BOOL unsigned int
or a typedef
typedef BOOL unsigned int;
You have to find out with the programmer which data type it is. I would expect that it is a int or unsigned int which is on the Windows I32 or U32.
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
(2,660 Views)
