Error 200329 on a TBX 68
I have an error 200329 when using TBX 68 for DAQ, the DAQ device is NI PCI-MIO-16E-1
the labview program is a simple analog input reading using DAQ assistant on a chart
The Labview is 2013, and the NIDAQ is 16.0
(3,183 Views)
Can you attach your actual VI?
The problem with using a DAQ Assistant Express VI is that all details of how it is setup are hidden inside, so a screen shot of a blue box on a block diagram doesn't tell us anything.
(3,167 Views)
Thanks for the reply
here is the VI
(3,150 Views)
Okay.  The information within the DAQ Assistant seems pretty normal to me.
The TBX-68 is just a terminal block, so it shouldn't be the cause of any issues.  Just to be sure, disconnect it and try to run your VI.
I'm thinking 1 of 2 things.
1.  That card is no longer supported by DAQmx 16.  (I don't know that.  I have a hard time finding on the website when support for holder cards get dropped.)
2.  The card is damaged in some way.
That is all I can offer.  Hopefully someone with more experience with this card can jump in and provide some more info.
(3,118 Views)
