Error 200560 while generating two AO signal
I am trying to send two Analog signals out and I keep getting the error 200560 at 'wait until done' vi.
I was wondering if there is any solutions to fix this problem.
btw the vi is attached.
Pooya
(3,735 Views)
Accepted by Pooya
You have your clock set to continuous samples. I don't know if you can use "Wait Until Done" If you task will never be done. Set your click to finite and see what happens.
(3,724 Views)
Thank you so much Citabira.
you were right, I just forgot to change it to finite sample.
It is working now.
(3,719 Views)
No problem. A kudo would be nice if you feel I deserve it 🙂
(3,716 Views)
