Error -200609 occurred at DAQmx Write: Selected Buffer Size Too Small
Hello, I'm writing some simple test VI's that I will eventually build upon to make an externally clocked analog output VI. I started with a very simple program to output finite samples using the onboard clock with the DAQmx Timing.VI. When I run the program, I almost immediately get an error. The error message is below.
Error -200609 occurred at DAQmx Write (Analog DBL 1Chan 1Samp).vi:1
Possible reason(s):
Generation cannot be started, because the selected buffer size is too small.
Increase the buffer size.
Conflicting Property
Property: Output.BufSize
Corresponding Value: 1
Minimum Supported Value: 2
Task Name: _unnamedTask<1C>
I have used DAQmx VI's before in similar applications and never encountered this error. Additionally, I read at the link below that DAQmx Timing.VI should be generating the buffer automatically. Any ideas as what could be causing this?
Specs:
Windows 7
Labview 2012
PCIe-6353 as DAQ board
Below is a picture of my block diagram and the VI is attachedFiniteSamplesTestBlockDiagram.PNG.
(5,219 Views)
Accepted by EBPhysics
Oops. Just realized my very silly mistake: I forgot to add the Start Task VI. I did so and it works as designed.
(5,216 Views)
Could you specify where did you add the DAQmx Start VI?
(4,320 Views)
This is 2 years old thread and the original poster last visited this forum on 2015 and hope you MAY not get any reply from him. Hence kindly create a new topic and give more details. Are you getting the same error what the original poster mentioned?
Mathan
(4,306 Views)
Hi Mathan,
Thank you for your kind reminder about the original post.
Yes, I keep getting the same error. I have a USB6001 DAQ. I would like to have two synchronous analog signal from my DAQ (AO0 and AO1).  I was able to generate the generate the signal but having issues for taking it out from the DAQ port.
In this VI, as a first step I'm trying to get one signal from one of the AO.
Any help is greatly appreciated.
Best
(4,269 Views)
Hi Mathan,
I just created a new topic under the title of  "Error -200609 occurred at DAQmx Write: Selected Buffer Size Too Small".
Thanks for your help in advance
(4,260 Views)
continue here!
(4,254 Views)
