Error (2147136858) CANOPEN interface:658001
I got this error with CANopen Interface 658001. What is it?
(3,175 Views)
Hi Zhang,
again you forgot to attach your VI and to mention the type of hardware and software you are using! I guess it is related to this thread!?
Did you read the error message? Did you follow its suggestion?
(3,139 Views)
−2147136858 The property value or the parameter value is not valid. Ensure the property value or the parameter value is in the valid range.
The error with 2147136858 should check the value by setting parameters. I have checked them.
You can see the picture. The error began from this Flat Sequence structure. I guess it has some parameter with this structure conflict.
Thanks!
(3,116 Views)
Hi Zhang,
The error already comes out of "CANopen Interface Create"! (Which you should be able to notice when using Highlight Execution debugging…)
There is a coercion dot at one parameter of that function: what happens when you remove that coercion dot?
(3,111 Views)
