How to run the following program? 5646r hardware is needed
I am a beginner. I hope to get detailed instructions. Thank you very much.
(2,566 Views)
Did you read the pretty thorough Documentation (a PDF, a Word Document, a readme.txt file)?
I notice (from the Documentation) that these files and documentation are pretty old (the Documentation refers to LabVIEW 2012 and 2013, and a VI opened at random was saved in LabVIEW 2015).
I don't know if the "5646r hardware is needed" in your Subject line is a Question or a Statement, but the documentation definitely refers to this hardware, and I suspect it is, indeed, needed.
Bob Schor
(2,519 Views)
i try compile the fpga but false
(2,464 Views)
no one can answer this?
(2,446 Views)
Hi chen,
Answer to what? (Maybe you should be a little bit more specific?)
Which problems do you encounter?
Which software do you use?
(2,439 Views)
