Error -2318 occurred at Integrator.vi -> The dimension of the parameter vectors of this function do not match
Hi Arjun,
why do you need to post your VI four times?
And where is that "Integrator" problem in your VI?
Message 11 of 13
(563 Views)
hi. I have this problem, too. can you help me please?
Message 12 of 13
(543 Views)
Hi marzii,
which problem do you encounter? At which function?
And why do you set a dt of 0 at the integrator?
Why are there two more unused instances of the integrator?
Message 13 of 13
(531 Views)
