Error 2519 LabVIEW could not load the TDMS file component
This is the expected behavior. The 2 folders are for 32-bit and 64-bit.
Message 11 of 31
(3,080 Views)
Hi Chithanhvn!
Those TDMS folders are supposed to be there. But I had a third folder in C:\users\[me]\AppData\Roaming\National Instrument that may have caused problems (When I whiped it and re-installed, things worked).
Beware though: if your windows is in another language (like I had), you wont see these folders in your windows explorer.
You can however type it in in the adress field, you'll find it there.
Hope it helps, good luck!
Message 12 of 31
(3,058 Views)
Thanks Erik
Message 13 of 31
(3,048 Views)
Thanks Yongqing!
Message 14 of 31
(3,046 Views)
I am having similar issues and results.  I have repaired installation on LV and TDMS.  I have not started a clean machine build.
Runnning 32-bit LabVIEW (15.0f2)
Has 32-bit TDMS library (15.0.0.49152 file version; 15.0.0f0 product version)
What was the "app" folder that you cleared before success?
Message 15 of 31
(2,989 Views)
You don't need to clear the directory before installation. You only need to install the latest TDMS component, from this link:
https://www.ni.com/en/support/downloads/dataplugins/download.ni-dataplugin-for-tdms.html
Message 16 of 31
(2,985 Views)
I tried that installer, twice. I have verified the labview version and TDMS versions were consistent. And I have repaired both LV & TDMS installation. Is there an install log that can tell me what might not be correct
Message 17 of 31
(2,978 Views)
Alright, so please check which bitness of LabVIEW you are using, 32-bit or 64-bit?
If 32-bit, TDMS component should be in C:\Program Files (x86)\National Instruments\Shared\TDMS folder. If 64-bit, it should be in C:\Program Files\National Instruments\Shared\TDMS folder.
Message 18 of 31
(2,975 Views)
Correct: 32 bit LV ( x86 folder) with 32 bit version of TDMS dll.
Message 19 of 31
(2,969 Views)
Then it looks a little bit weird. Maybe you can try to clear that directory before installation, and make sure TDMS component appears again in the directory after the installation.
Message 20 of 31
(2,951 Views)
