Error 26096 LabVIEW 6.1 application builder
When I run the application builder with create installer, I get the error code 26096: NMDK_AMM_UNSPECIFIED_MERGE_ERROR and the path to 'ActiveX Container.MSM'.
What is going wrong and how can I resolve this problem?
(3,288 Views)
Andreas
Take a look at this forum thread, it explains the problem and the solution for you.
Merge error when creating installer for .exe
(3,277 Views)
Evan,
thank you very much for your quick reponse. The link helped. The search engine at NI-Zone didn't find anything with this error code.
(3,268 Views)
