Error 5003
Hi all ,
I am trying to get my arduino to work Using LINX (makerhub) and I previously hadn't any issues but now every time I try connect I get the Error 5003. This is particularly frustrating as i can control the board using the test platform in NI MAX. help please as this is stalling my work to a stop. P.S I've tried to load the led blink test and receive the same error.
(3,681 Views)
Error 5003 is a "User-defined Error".  NI reserved a range of Error Codes (including a bunch starting at 5000) for Users (like you and I) to use for Errors that we decide.  It's coming from your "Open" VI, which you didn't attach, so I can't tell you where it is, but inside there, someone is using something like the "Error Cluster from Error Code" VI and wiring 5003 as the Error number.  RTFM (Read the Manual), or attach the failing Open VI (which we might or might not be able to open ...).
Bob Schor
(3,592 Views)
(3,570 Views)
