Graph Scale missing name probelm
Hello all
In my application I have to change the names and ranges of the graph scales, I need to hide the scales or show the scales.
The problem is when I'm hiding and the showing the scale. After show the name of the scale is missing. Please Have look at the code
Best Regards
(3,077 Views)
For unknown (to me) reasons, the fourth scale needs more room horizontally. Resize the plot area until the scale name appears.
Paolo
LV 7.1, 2011, 2017, 2019, 2021
(3,040 Views)
Thank You for work around but in this solution it looks very bad space between scales is to big. I would like both sites looks the same.
(3,009 Views)
Sometimes control can behave awkwardly.
Delete the offending scale and create it again. I was able to get a normal width scale this way.
Paolo
(2,990 Views)
