Error -50103 occurred at DAQmx Start Task.vi:2
I am trying to run the program that is attached, and am receiving this error after I run the program after the first time. Meaning, if I run the program initially, it works fine, but after I press stop, and then run again for the 2nd time, the program gives me the above error and message below:
Possible reason(s):
NI Platform Services:  The specified resource is reserved. The operation could not be completed as specified.
Task Name: _unnamedTask<2F>
I initially thought it was because I am not clearing out the task correctly, so I put a Clear Task icon outside of the while loop on the bottom, but it is still giving me that error. Any help I would greatly appreciate as this is for a school project! 🙂
(3,142 Views)
This link might help you out.
(3,139 Views)
