01-26-2010 09:12 AM
I got this error while trying to do very basic analog out program. Don't really understand it. Could anybody help me?
FYI, I am using USB DAQ 6211.
Error -50405 occurred at DAQ AssistantPossible Reason(s):No transfer is in progress because the transfer was aborted by the
client. The operation could not be completed as specified.
01-26-2010 10:15 AM
This error indicated that you are having connectivity issues with your USB connection. This could be a bad USB port or something else. If you are going through a USB hub I would suggest you connect directly to the computer as hubs provide inconsistent power sometimes. I would also read the following Knowledgebase article about this error.
http://digital.ni.com/public.nsf/allkb/3EA2432762C45B298625734D0061D527?OpenDocument
01-26-2010 01:19 PM
01-27-2010 11:15 AM
Can you try your restore again and run a Test Panel in MAX, just to elimnate your software code as a possible issue.
If you are still receiving this error, do you have another computer you could try this in to eliminate the possibility that there is an issue with your USB power supply. Using another 6211 on the same computer could also help with this step.
Is there anything else plugged into your USB ports (besides mouse and keyboard) on the computer?
