Error -50413 occurred in the test panel
Hello everyone, I am using the PCI6143 acquisition board. The problem is as follows: When running a program in Labview, an error is reported at the end of the acquisition 1.Error -50413 occurred at DAQmx Read (Analog 2D DBL NChan NSamp).vi:4960001 Possible reason(s): NI Platform Services :A transfer was aborted because of a hardware error on the bus which the transfer was occurring。 2.1 In the DADmx self-test panel, the analog input, mode selection is as required, the channel is operating normally 2.2 In the DADmx self-test panel, the analog input, the mode selection is continuous, an error is reported. Error -200010 occurred in the test panel Possible cause: The onboard device memory overflows. Due to system/bus bandwidth limitations, the speed at which the driver reads data from the device cannot keep up with the data output speed of the device. 2.3 In the DAQmx self-test panel, the analog input, the mode selection is limited sampling, an error is reported. Error -50413 occurred in the test panel Possible cause: NI Plat Services: The transfer has been aborted due to a hardware error in the bus used for the transfer 2.4 In the DADmx self-test panel, the digital I/O counter I/O, the channel is operating normally. How should I solve it? Sincerely look forward to your reply.
(2,487 Views)
Hi Djun,
Can you try this board in another PCI slot or on another computer? We want to verify that this error is with the card and not the PCI slot itself.
Best,
Claire C.
AppSW Staff Product Support Engineer
CLD|CTD
(2,410 Views)
