Saving the entire Test and recordings (Graph as well as graph Readings ) after every test
Hi everybody,
I believe somebody can help me in this problem. I don't know how to save the entire test Front panel with Graph and recording so that I can  just replay it once again to show somebody.
For example, on my front panel there is a graph and Gauges, if I run a test for 5 min, how can I replay the 5 min of my complete test next time.
(2,138 Views)
Hi AJ28,
Can you post your code or at least screenshots? It might be fairly easy to implement that replay functionality just by writing to a file and then reading it back at the appropriate intervals, depending on what your existing code looks like.
Best,
Claire C.
AppSW Staff Product Support Engineer
CLD|CTD
(2,062 Views)
Operate >>> Data Logging >>> Log ...
Then use the other options to play it back.
Ben
(2,049 Views)
