Error 56 - Labview TCP interaction with Cognex help
VI attached. Using Labview 2022 Q3.
Trying to open a TCP connection with a Cognex InSight 7802 camera.
The VI has an error 56 (source TCP Read)  which happens after I try and send the admin login.
Flow order - TCP open connection --> TCP Read, CRLF, 100 bytes (this outputs Welcome to InSight 7802 Session 0) --> TCP Read, 6 bytes (This outputs User:) --> TCP Write, attempting to input admin\r\n --> TCP read, 10 bytes (Error 56). If it was performed properly, the below should be output.
I've tried varying byte amount, varying the order etc but am stumped!
Feels like it isn't sending the 'admin' command or something.
Any help would be greatly appreciated.
(3,002 Views)
Is that screen shot from a Telnet or SSH session? Telnet or SSH is NOT raw TCP/IP but has some more or less complex signaling (SSH also has transport encryption!)
Rolf Kalbermatter  My Blog
(2,959 Views)
Accepted by topic author JOECAMM
Your error is in string constant! You cannot write \r\ln in a normal string constant. You have to activate code display!
(2,937 Views)
Thanks a lot - worked immediately!
(2,866 Views)
Have you been able to display the Cognex image on LabVIEW or also show the field strip?
(1,963 Views)
I used the native commands and was able to retrieve the data. However, I am
struggling with retrieving the image and the filmstrip and displaying them in LabVIEW. This part I couldn't figure out yet.
please if you could help me with this I will be thankful.
(1,741 Views)
