VISA: (Hex 0xBFFF0071) A specified user buffer is not valid or cannot be accessed for the required size.
I am using the VI in attach for resetting the switch modules in HP34970A Keysight instrument.
For some reason when i update the test station with IOLibSuite_18_3_29324 this error appears... :? Anyone has similar experience?
error: VISA Write in HP34970A Reset Modules.vi VISA: (Hex 0xBFFF0071) A specified user buffer is not valid or cannot be accessed for the required size.
(444 Views)
This VI cannot run on its own, we need to see your entire program.
How are you initializing and opening the VISA session?
BTW: I have been using the HP/Agilent/Keysight 34970A for decades and have never needed to use this VI.
So I suspect something else is going on in your program.
Also if you are only using this instrument with LabVIEW you do not need to install the "I/O Suite", that is only needed for their Benchlink software.
NI-VISA and NI Measurement and Automation Explorer (NI-MAX) provide the same functionality for LabVIEW that the I/O Suite provides for their Benchlink software.
=== Engineer Ambiguously ===
(405 Views)
Thank you for your feedback.
The initializing was passing and actually same test setup was working fine locally on my PC.
So I couldn't find what could be the issue with it, but most probably test station had bunch of other things installed and hard to be tracked all that remotely.
So i try out with other VI that actually will to the same job, and it worked 🙂
In attach the replaced VI.
(348 Views)
