JT1958,
These types of errors are a bit tricky to diagnose. I would try the following, in order of easiness:
1) Mass compile your project by doing a <Ctrl-Shift-Run> on your top level VI to make sure your project is linked correctly. Sometimes if there is a bad VI reference somewhere you can have these types of problems.
2) The path being to long most likely isn't the issue, but if you suspect the IOTech driver, you may try taking it out of your code and see if that allows you to build a source distribution. If that works, try creating a simple project that contains VIs from the driver and see if you can get it to build. The point is to narrow down what specifically is causing the build to fail.
3) You can try to build this in LabVIEW 8.2 as some improvements to the source distribution builder were made.
Doug M
For those unfamiliar with NBC's The Office, my icon is NOT a picture of me 🙂
