Error 62 in my application
Hello everyone,
I get this error while I am using the TCP Write functionality in my code. :
Error 62 occurred at TCP Write in TCP_Data_Client.vi
Possible reason(s):
LabVIEW: Serial port overrun error.
Can anyone give me a small explanation on why it happens? I am using the serial port (buffer size 4096) but it has only 162 bytes in its buffer.
(4,058 Views)
Error 62 means also "The system caused the network connection to be aborted".
Which operation system is used? Here some words about WindowsNT:
Error 62 and Error 66 in the TCP Examples Under Windows NT
http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/76d7453569e80a09862566da0056b30d?OpenDocument
(4,058 Views)
I am using WinXp on a P4, 2.4GHz machine.
(4,058 Views)
