Error -63043: Refer to NI KnowledgeBase article 4CJDJBLX
I got this error on my sbRIO. After 4 seconds, my real time program timeout and not able to connect.
The sbRIO is powered by 19V 500mA. Probably this affect the sbRIO?
The FPGA compilation is slower than usual compared to when I use a power switching regulator
Edit: Please move this into sbRIO, I posted in the wrong section
(3,471 Views)
Hi augustg
Have you try look at the article mention in the error code?
http://digital.ni.com/public.nsf/allkb/B746EA10EA65BE894825733D006BEA8F
You have mention that it is slower than when you use the power switch. Did you do any modification to your code before changing to the new supply?
TuiTui
(3,437 Views)
I managed to fix it with using a more power LiPo battery. Apparently i think it was power supply issue
(3,429 Views)
