01-29-2008 02:16 PM
01-29-2008 02:34 PM
01-29-2008 02:50 PM
01-29-2008 03:06 PM
I would suggest you do that, at the very least to avoid having a VI which can pop up a dialog. This VI is very old and not written in great style.
Gravy Train wrote:
unless I write my own Read Characters function.
01-29-2008 03:21 PM
01-29-2008 03:42 PM
Thanks guys, rewriting Read Characters From File vi sounds like the way I will go. It is still frustrating to not konw why it work for 3 years and then suddenly "No Dice" Strangely enough, as I was finishing up my last post, my two local NI sales contacts walked into my office, so I got to beat them up for a bit about this problem. They had similar advice as you guys posted about rewriting the VI to conform to better programming style, they also suggested to load the NI development environment out on my application computer to trace throught the execution problem exacly as it is happening on the application. Unfortunately that is kind of a drastic approce, but if I want to truly get to the root cause, that may be the only path.
