Error 7 - File path - How to tell which path?
You could do a text search to try to find the name of the file that isn't being found.
Bill
CLD
(Mid-Level minion.)
Message 11 of 14
(1,217 Views)
Here's what I ended up doing:
Put about a gabillion probes on different case structures that had file references in them.  Hit run (normal speed) and counted loop iterations of all 8 main loops.  They stopped at the second iteration.  If I hit continue on the error, one loop would run like crazy while another error threw...  8 clicks of Continue and they were all running.
There are two case structures in each that have file references in them, so I case-structured out 7 of the 8 main loops and ran the one slow with highlight execution - it stopped when it got to the second case structure.  In it was a subvi, in a subvi, which had a file reference that was one character off -- and that reference had been copied 8 times.
Long story short, I need to go back and put in some error handling in this thing, but the highlight execution and probes really helped.  I was hoping for a quick and easy 'click here for verbose logging' like Windows, but it worked.
Thanks all.
___________________________________________________________________
Still confused after 8 years.
Message 12 of 14
(1,207 Views)
This sounds like a situation where a breakpoint or conditional probe might have been more useful. They would allow the program to run at full speed until execution reaches a certain point (breakpoint) or a particular condition is met on a value (error boolean = True). The program pauses, you turn on highlight execution then let it resume.
Hardcoding file paths can have its drawbacks also, as you discovered.
Lynn
Message 13 of 14
(1,206 Views)
Just glad you were able to hunt it down.  🙂
Bill
CLD
(Mid-Level minion.)
Message 14 of 14
(1,195 Views)
