Error 7 occurred at Create Folder in Create Directory Recursive.vi-
Recieved following message when attemoting to create source distribution
Error 7 occurred at Create Folder in Create Directory Recursive.vi->ABAPI Dist Create Directory Recursive.vi->ABAPI Dist Chk for Destinations.vi->ABAPI Copy Files and Apply Settings.vi->SDBEP_Invoke_Build_Engine.vi->SDBUIP_Build_Invoke.vi->SDBUIP_Build_Rule_Editor.vi->SDBUIP_Item_OnDoProperties.vi->SDBUIP_Item_OnDoProperties.vi.ProxyCaller
Possible reason(s):
LabVIEW:  File not found. The file might have been moved or deleted, or the file path might be incorrectly formatted for the operating system. For example, use \ as path separators on Windows, : on Mac OS, and / on Linux.
(3,877 Views)
Could you please list which options you are selecting when building a source distribution (I am assuming you are using LabVIEW 8.0?).
Do you get this error when clicking on "Generate Preview" button when configuring source distribution properties?
Under "Distribution Settings" category, could you try checking the "Disconnect type definitions and remove unuses polymorphic VI instances" option and see if that helps with the build process?
Also I suggest Mass Compiling your VIs (Tools -> Advanced -> Mass Compile) before creating a source distribution.
If these do not help, could you attach your project with all the VIs it contains here?
Thank you and best regards,
Shakhina P.
(3,860 Views)
