Error 7 occurred at Open/Create/Replace File in Write Spreadsheet String.vi
 I am attempting to use a CompactRIO with 9225 analog input module to measure some analog signal.
LabVIEW version is 2013 (32bit), when I run th VI, errot 7 occurred.
I'm pretty sure the file path is correct , but the error information indicated different path used "\" not "/", I attached the picture.
I don't know why it happen, appreciate any suggestion to solve this problem.
Thanks.
Frank
(5,628 Views)
It is looking for the file on the RT system, which is not windows.
(5,620 Views)
That's the point! Thank you.
Ithere any instructions about write data to computer, not cRIO?
Frank
(5,604 Views)
Accepted by Feelgoodev
The cRIO-9075 doesn't have the ability to mount a Windows network share and read/write directly with the host computer.  What you would have to do is FTP the file from the host (the host has a client, and the RT system has a server) or run an FTP server on the host that the target can interact with (the host would then have a server, and the target has FTP client VIs) in order to get the file to the location it needs to.
-Danny
(5,593 Views)
Thank you for the information.
(5,566 Views)
