Error 7 when using Word Easy Table in built application.
I have built an application that uses the Report Generation for Microsoft Word LabView add-on.
The application works perfectly when I am running within the LabView build environment. I can also use the application builder with no problem at all.
Unfortunately, when I try to run the application that was built, even on the same development machine, I get the following error:
"Error 7 occurred at Open VI Reference in Append Text Table to Report.vi -> Word Easy Table (str).vi -> ReportZone.vi -> Report.vi"
'ReportZone.vi' and 'Report.vi' are my VIs. 'ReportZone.vi' uses 'Word Easy Table'. As I specified, there is no problem at all running this from within the build enviroment. This only fails after I build an application and try to run the built application.
I am using LabView 7.1 under Windows 2000.
Thank you in advance for any help you can provide.
(2,745 Views)
I tried searching the NI Support pages again, using a variety of applicable words.
Finally, I found the answer that I needed right here:
http://digital.ni.com/public.nsf/websearch/86256A47004E16D186256A84004CB883?opendocument&Submitted&&node=133020_US
(2,732 Views)
