Read file in LabViewwith a DLL create in CVI get problem with EOF
I have writen a CVI program that reads a text file till the EOF comes. I made a DLL out of it and call this DLL in LabView. In CVI the EOF returns -2 in LabView not. So I get an runtime error . Is there any way to use this CVI DLL.
(2,943 Views)
CVI made dlls should work in dll. Can you post your example code? Is there any text with error -2?
(2,928 Views)
I write two short program in CVI that reads in a text file with a frequency list One a DLL and on as calling program to test the DLL. It is in one workspace an works fine. Than I use the DLL in LabView. I made a VI. It didn't get the EOF also no frequency values ?
I put all in a Zip file.
Thomas
(2,921 Views)
Hi Thomas,
the problem is not a EOF problem. Can you please explain the following construct:
if (Load_Save_Info.RunFlag == 0 )
MakePathname (filename,DEFAULT_CHANNEL_TERRESTRIAL, filename);
strcpy(FileToRead,filename);
else
FileSelectPopup("","*.txt",".txt", "Select file",VAL_SELECT_BUTTON,0,0,1,0,FileToRead );
if (DLL == ON)
FileSelectPopup ("", "*.txt", ".txt", "Load file", VAL_LOAD_BUTTON,0, 0, 1, 0, filename); //(*)
String_Length_All = StringLength (filename);
You always read the "FileToRead" whatever the enquiry returns. That means if you change the line (*) to
FileSelectPopup ("", "*.txt", ".txt", "Load file", VAL_LOAD_BUTTON,0, 0, 1, 0, FileToRead);
it works. I've tested in LabVIEW.
Regards
Kai Kratt
NI
(2,913 Views)
Hallo Kai
Thanks a lot that was the point.
I take that sammle out off an existing program so the construct is related to that.
with best regards
Thomas
(2,904 Views)
