Error 70012
Hi.
I have a 7344 cotroller, I'm trying some motion control helps and I receive the 70012 error message (illegal board ID), but the board ID set on the .VI is 2 and the same is on MAX, in fact I can read PCI-7340 (2).
Where's the mistake?
(4,795 Views)
No one can help?
(4,767 Views)
take a look on this document:
Why Do I Get Error -70012 When I Try to Initialize My Motion Controller from a Built LabVIEW Application?
http://digital.ni.com/public.nsf/allkb/479BEE5E530908F286256E520044563E?OpenDocument
Let me know if you will resolve the problem.
Beppe
(4,757 Views)
Check your wires, you probably switched the axis and board wires for some node
(4,114 Views)
