Installing Correct Version of LabView
I am trying to verify my LabView is working correctly.
The class syllabus I was given supplies me with the following instructions:
If you want to check that your myDAQ and LabVIEW are both working correctly, launch LabVIEW, create a blank VI, right click in the white space of the block diagram, mouse over input, select DAQ Assist, click to drop the DAQ Assist block onto the white space, select the plus next to “Acquire signals”, then the plus next to “Analog input”, then select “Voltage”.  Your myDAQ should be listed under  “Supported Physical Channels”
When I right click in the white space of the block diagram and mouse ofver "input" I do not see "DAQ Assist".
Please Advise.
Steve
(2,670 Views)
(2,662 Views)
