Error 72 can't creat Crio project
Hi all,
I have been facinng this problem for several days. Every time I try to create a Crio project, I get this error message.
I deleted labview and reinstalled it and nothing has changed I have a student license
thank you for advising me, thank you all
Message 1 of 12
(2,853 Views)
How did you uninstall LabVIEW? Through the package manager or through windows add/remove programs? Try doing it through the package manager if you didn't do that the first time. There is also a 'Repair' option in package manager which has worked for me on a couple of quirky bugs like this recently. It might be worth giving that a go.
Unfortunately the VI that is broken is part of the LabVIEW install and is password protected so you aren't going to be able to debug/fix it yourself.
A work around may be to create a blank project and then add a cRIO target manually by rclick on the project/new/target or device
Message 2 of 12
(2,817 Views)
Hello, thank you for your answer. I tried both options but neither worked for me.
Message 3 of 12
(2,811 Views)
Did adding a crio target to blank project not work either?
Message 4 of 12
(2,807 Views)
Hi Niatross i could, but i couldn't add the FPGA target !
Message 5 of 12
(2,790 Views)
What is stopping you from adding it? Is the menu item not there, an error message or have you you got a yellow triangle with an explanation mark in it next to the crio target?
have you definitely installed both the real-time module and fpga module when you installed labview?
Message 6 of 12
(2,774 Views)
hi again i added the drivers, the modules and everything
when i creat a new project that's what i find
so i think it's a licence issue please look at the screenshots image.pngimage.png
Message 7 of 12
(2,749 Views)
Hi wafa,
What's wrong with this?
You already have a project containing a host computer and a cRIO RT target, and you just found the option to add a FPGA target to your cRIO target…
Message 8 of 12
(2,735 Views)
Hi, That's the issue i have everything the drivers and the modules installed when i click on add fpg target nothing adds and when i creat a Crio project i receive that error !
Message 9 of 12
(2,716 Views)
@wafa.02 wrote:
 What happens if you select the FPGA module and press activate?
Message 10 of 12
(2,702 Views)
