Error 8 occurred
I had the same error (Error 8 file access error in building applications) with LV 8.2.1. Granting full access rights to several directories wouldn't help. Deselecting the "Copy error code files" option in the build definition did help, but wasn't really a viable option in my case.
Well, I learned from here that executables do not automatically inherit admin privileges even if the user has them in Windows 7. But you can grant those rights to the program, for example by pressing shift+ctrl when you start LabVIEW.exe -- this did the trick, build complete!
Message 11 of 12
(827 Views)
Hi guys, I guess I found and solved the problem. The problem wasn't related to LabVIEW. Always when I used Mozilla Firefox I couldn't compile my applications. I've now installed the latest Mozilla and now it seems to work. Many thanks to everybody who was thinking of this problem.
Message 12 of 12
(802 Views)
