Error -8004 occurred at Keithley 2600 Series.lvlib:Print Buffer Data.vi?
I am working with a Keithley 2602 A. I installed the drivers and looked up an example to test the Keithley. The example that I am using is called current read measurement (image attached).
The problem is that once I run the example I receive the following error:
I also attached a video on how the situation unfolds.
https://www.veed.io/view/497f235c-dc74-4444-be85-323d4f85b808?sharingWidget=true&panel=share
Message 1 of 1
(1,227 Views)
