Error 85 occurred at Scan From String (arg4)
I am trying to scan in hexadecimal values and convert it into decimal values from a text file.
The file I am scanning from consists of linessuch as
DSDS S0=00002B5D S1=00002AD5 S2=00001C9E S3=00001050 S4=00000003 S5=D2BF3769
I am trying to convert the S0, S1, S2 , S3, S4 AND S5 to decimal values. But I keep getting "Error 85 occurred at Scan from String (arg4)". I am not sure what I am missing here. I have attached the vi below.
Message 1 of 12
(6,121 Views)
Just add '%s ' to the beginning of your format string to grab the start of the string, (make sure you add the space after the %s)
Message 2 of 12
(6,108 Views)
Putting "DSDS " at the front of the format string works also but is not as flexible as Darin's recommendation.
Lynn
Message 3 of 12
(6,100 Views)
I am not sure what I am doing is right. But where do I exactly add the %s. A image description will be of more help.
Message 4 of 12
(6,085 Views)
Where you have it is fine.
Lynn
Message 5 of 12
(6,082 Views)
But I am still getting an error " Error 1 occurred at Scan from String -input parameter is invalid"
Message 6 of 12
(6,077 Views)
I do not get any error and the outputs seem reasonable when I run it using the string you posted in the first post of this thread.
Lynn
Message 7 of 12
(6,053 Views)
Using the string you posted in your earlier message in the VI you posted, it works just fine for me.
Are you sure you have a complete, accurate string?  Post your VI with the string that fails saved as the default value in the string control.
PS:  You don't need to wire a constant 0 to all of those inputs.  The default value is already 0.  And the datatype will default to the datatype of the indicator you wire in.
Message 8 of 12
(6,051 Views)
This is the VI I have got. But I still keep getting the error input parameter is invalid. Can you just post the vi you think which works fine so that I can cross check what is the mistake.
Message 9 of 12
(6,019 Views)
As Raven said above, please post that same VI with typical data saved in the control as default values.
Bill
CLD
(Mid-Level minion.)
Message 10 of 12
(6,007 Views)
